Hi all, i have a Stiga Park Pro 16 which just arrived today, a second hand one in real nice condition and well maintained.
Getting it off the pallet on the truck was a nightmare, and i am worried it may have had a bump underneath which bent something, but I don't know what it should look like so I dont know if it's bent!!
Basically I noticed a spring hanging off when I got it into my barn and i took a pic as it looked then....
I spent two hours underneath trying to see where that spring should go. I didn't even know if it should be attached to where it is in that first pic! I found an exploded diagram online, loads of them in fact, and none of them make enough sense to show me where it goes. I eventually stuck it onto the mower deck tensioner pulley, like this.....
But it just doesn't seem right there. I tried starting her up and engaging the deck and it did engage, but i could smell burning rubber so instantly shut her off. The belt doesn't seem to be sitting nicely against the side of the tensioner pulley, it is kind of offset, as shown below....
I had another look underneath and it suddenly occurred to me that maybe it did take a whack underneath and maybe the steel arm which the pulley tensioner sits on got pushed up and bent? See next pic below.....
Does anyone know if this should be horizontal to the ground or should it be up at an angle like it is? I have marked with arrows the part I mean, and the bigger of the two arrows shows the direction I suspect it might have been pushed. Should it sit at that angle or should the wheel be exactly parallel with the other pulleys? The final picture shows it a bit better, how the tensioner pulley wheel is not at same angle as the pulleys which hold the belt......
I am really hoping somebody on here either has one so can compare, or has worked on one and knows the answer! Its awful seeing something for the first time in your life, and not being sure if its had a bang or not!! Thanks to anyone who can help
