Husqvarna GT48 XLSI the I means that stupid smart switch thing,
. Whole story, cutting grass and the blades stop turning. Go to the house blow all the grass off the deck and check underneath for any problems. Nothing, engage blades seem to be ok cut for a few minutes same thing they stop. Read online this could be caused by a weak battery. Yes battery is WEAK' Replace battery and as soon as the second post is connected it starts cranking. Figure solenoid is bad replace it same thing, soon as the last battery post is connected it starts cranking like crazy. The only other thing I can add is the stupid smart switch never lights up, if it does its so fast unless you are watching it you will miss it. I am about to go crazy on this one. LOL Thanks for any help or opinions
