stalls under load
pack12
briggs 26 hp intek when it mows for15 min. you need to run on full choke 1/2 throttle , it will stall then restart fine. it like chokes itself out under a load when deck is on
Start by cracking the gas cap open to allow air in. The vents may be plugged causing a vacuum in the tank. Do this as soon as you feel it starting to stumble.
