Someone kindly sent me to the spark plug replacement site to check out a replacement for a TorchF6RTC plug.
The suggested replacement seemed to be Champ. RN11YC.
I ordered that from Kohler (thru Home Depot) and they sent me Champ. RC12YC.
Will that work?
Thanks,
JD
Yes it should work not a problem.
The RN11YC crosses onto an NGK BPR5ES which is the about the same plug as the champion RC12YC.
Oh, Boy...two replies...two opinions.
Maybe I should ask if the RC12 would do any damage to the mower?
What engine is fitted so that you can get the right plug fitted?
If the spark plug came in the engine from the factory would you think the F6RTC would be the right plug?
