The Brain
you know I hate to think about it but I was having a no spark issue an couldn't find the spark tester so I removed the spark plug an placed the spark plug near the cylinder head cranked her over to see if I had spark. what I had was a huge fireball from all the fuel shooting out the spark plug hole scared the crape out of me.The spark plugs will be wet with fuel and fairly clean, if there is that much fuel getting into the cylinders. If that's the case, I'm surprised that you haven't experienced a hydro-lock situation.
I just can't imagine that much fuel on top of the cooling fins coming from inside of the engine. Oil can certainly show up in that area.
I had Kawasaki Mule that would carbon foul the plugs. It eventually got worse. It progressed and hydro-locked the engine. I pulled the plug and cranked it over. Gasoline shot out of the spark plug hole. I changed the carburetor, plug, and traded that nightmare.
I never thought there would be that much fuel shooting out the sp hole. there's definitity something wrong w/ the fueling.
I also neglected to mention the cylinder head swap from the orginal engine. remember my thread about adjusting the valves? anyway I reused some of the old orginal engines valves. I also reused the old cylinder head gasket. pretty sure I tightened the cylinder head down tight. tightening from inside to outside in like 3 pass's.
I'll clean an inspect real close, if I don't see any visiable cracks then remove head an inspect the head gasket. will report back. thanks MParr
