good news is snappers up an running w/ new head gasket an new carb.bad news is she won't turn off w/ ignition key switch.I can't remember if that wire I disconnected at coil is the after effect? IIRC I'll have to ground that disconnected coil wire to turn her off?
here's all what I did the torque wrench was useless at 6LBs also w/12LBs even the 3rd pass I never felt it click, once I think on 12LB I felt a tiny give but not click so I did each pass by feel 18isn't that much even w/ a 18" lenght. but torqued in correct sequence.
note my cylinder head had an extra bolt I counted it as #9 just under #8.
when I installed the new cylinder head gasket the piston was at TDC I still get confused on which TDC so I took a crape shot an adjusted valves. I couldn't find my complete set of feeler gauges. I did have the .005 so I adjust both valves to .005.IIRC I did that same adjustment last year.
if I adjusted valves on wronge stroke could this be why I hear this loud clacking noise. or could the valve be to tight?
she basically cranked right up this video was basically the 2nd startup. I didn't install new valve cover gasket BC I thought I'd have to readjust the valves I also didn't want the fuel mixed oil on the new paper gasket. even at .005 the gauge was in there tight.I believe this engine has .004 on one valve an .006 on other the ytuber darrel recommends .005 on both not sure about that. I should also mention I don't have an exhaust gasket.
not sure what that loud clacking noise is. when I reassembled the air box w/ new filter the heat shield wasn't tucked in under it
. I maybe hear some exhaust noise. hope I didn't hurt her to bad? thanks Guys I'll report back after fist mow.
sgkent the cylinder is horizontal and the blown gasket was on the top section thats why she shot fuel straight up like a skirt gun.
edit: I reused a preiously gas fouled spark plug and didn't check its gap. that will be fine later. how will I know if the fuel to air mixture is acceptable?
