kingofammo
- Oct 24, 2023
- Threads
- 1
- 6
Fine for 12 years then one day it would not shut down, and then wouldn't key start ..installed new switch and new solenoid but no change..
SYMPTOMS and CHECKS ...> meter doesn't light, jump starts on Run or ROS, then runs with switch in any position, ROS position works, will shut down only with key off of ROS while engaging blade and reverse, meter checked wires from switch to solenoid and starter all intact, fuse good, mouse damage on fuel pump wire (repaired) but no where else seen, the 3 wire headlight cable open connector was cut off by mower ...
NEED help diagnosing wiring diagram schematic checks for hidden faults please
