Snapper Wiring Issue-Three wires near starter-Model 250816BE
jimcahoe
  • / Snapper Wiring Issue-Three wires near starter-Model 250816BE
I have a 250816BE with a wiring issue with the three wires near the starter. The two wires coming out near the top of the starter are red and black. I have a single white wire that connected to these wires(one or both). The plug was damaged when I bought the mower. Some one sent me a wiring schematic but I still couldn't tell how to hook these wires up.
Currently the red wire is hooked to the white wire and the black wire is just hanging(I did this and I believe it is wrong). The mower runs rough(when throttle is set high I am only getting about a third power and is maybe miss firing a bit).
I can send a picture if anyone is an expert at the wiring.
Thanks to everyone for all their help.
mechanic mark
Jim, see if this helps and let us know if it does or does not.
Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
mechanic mark
Thanks but it doesn't. I can send you a picture of what I have if anyone there can tell me what to connect.
Thanks
Jim, Snapper model numbers are either 7 or 9 numbers & letters combined, 250816be is 8, please include all numbers and letters. Thanks
Black/Red will go to ground, meaning chassis or engine block,etc., 1 white wire goes to brown wire & 1 white wire goes to yellow/black wire.
jimcahoe
That is the model number on the mower and owners manual.
