Repairs Snapper SX825- Solenoid Issues
jimcahoe
I can't get my mower to start. I get a click under my seat when I turn the ignition. Is there anything I should check before actually replacing the solenoid? Is this a generic part I can get anywhere?
mechanic mark
Post model number please, should be 7 numbers.
Also post model, type, trim, from engine. Model number will be 6 numbers and or letters, type will be 4, trim will be 2.
model xxxxxx, type xxxx, trim xx.Engine
Is battery charged up? Inspect and clean all electrical connections, wear safety glasses, and make sure all connections are tight.
Results
Give this a try, will tell you where the problem is.
Electrical problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). *If you have power what is the voltage?
Fifth, check for power at the starter while holding the key in the start position (assistant again). *If you have power what is the voltage?
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
jimcahoe
1) 13 volts
2) 13 volts
3) 0
4) 0
5) 0
6) ok
Hopefully I answered everything.
jimcahoe
Can anyone tell anything from my answers.
Carscw
Put some jumper cables on it from the car battery to the mower battery.
You hear a click so your getting power so maybe the battery is week.
Mikel1
You said 0 Volts on #3, that's the problem. Read Rivets last sentence in his "Third" paragraph and that is your answer. If you don't have 12V on the small wire while trying to start then it can't bridge the voltage over to the other solenoid post leading to starter.
As Mike said the answer is at the end of step 3. 0 volts means you either have a bad switch, bad safety switch or problem with the wiring. You are now going to trace the wiring from the S terminal on the key switch to the solenoid. When you loose 12 volts, you will have located the problem
jimcahoe
I did forget to mention it does start with the rope pull when the ignition is in the on position. Does this narrow down anything else?
