Snapper riding mower
greg ray
My mower dies when the brake is released with the engine running. What is the problem? Help!
Most common cause is a seat switch or associated wiring harness problem.
AnthemBassMan
Does it run just fine with the brake on? If it does, check the safety switch.
Sent from my iPhone using LMF
Tinkerer200
IF you are needing to mow your yard, locate and disconnect the "kill" wire at the engine, mow your yard then check safety switches one by one.
Walt Conner
