Snapper RER Ignition Switch Problem
Mike12656
I have a Snapper RER 33114520BVE with 14.5 hp Briggs and Stratton engine and I’m having trouble with ignition switch —mower won’t turn off with ignition switch in off position so I have to throttle it down to shut it down
I got a new switch but starting working on it when it wasn’t summer so it was alot cooler out and basically gave up!
Now its hot summer in Florida
All the other safety switches were working
Now I went start the mower to do the lawn and it would not start I wasn’t getting a spark
So I replaced the spark plug and it started right up
Then I realized I was not on the seat and didn’t have the brake/clutch pushed in so apparently the brake/clutch and seat safety switches were not working
I get my best bet would be put in the new switch- trace the wire through the tube with a new wire and make all the connections
The wire that goes to the ignition switch obviously has the insulation rubbed off causing a short
Then I hope for the best
once the ignition switch is changed
Any suggestions or short cuts would be helpful Thanks Mike
First, would you double check the model number you posted? Could it be 3314520? If it is was the ignition switch you should have used is 7026343SM. Could you have gotten the wrong switch? A lot of switches look the same, but you must check the back of the switch and make sure all terminals are labeled in the same spot. Let us know and we’ll go from there, but we would only be guessing until you reply.
Mike12656
I will check the switch and get back to you
Mike12656
Ok I have a Snapper 7026343SM switch to put in to replace the factory OEM switch which is failing to shut off the engine
Not I don’t know if the wire is bad —insulation got rubbed off and causing a short or switch is just bad?
Now as far as the Snapper I have yet to find model/serial number plate it supposed to be on back frame according to Snapper but I looked and its not there
I will dig out the paperwork I have on the unit to see what the model number is—the guy I bought it from kept all records meticulously for this unit
Mike12656
Alright I have the numbers
Snapper 3314520BVE
Serial # 11348333
287707-1235E1
Serial # 009182E
thats info on what I have
—-Mike
Just note that ignition coils kill terminals do go bad. I would check the kill terminal is grounding as it should. If you don't have a meter then temporary connect a long wire to the kill terminal of the coil and ground it while the engine is running if the coil's kill terminal is good the engine will die and you have a wiring problem. If it don't die then the coil is bad.
Mike12656
Yes I tested the kill wire and it killed the engine when I touched it to ground
So I think I have a wiring problem
I was waiting on Revits to tell me how put in a new switch
Thats why I posted model/serial on mower- engine-switch
Unless you can help me
Simple, remove the bad switch, check the back of the switches making sure they are labeled exactly the same, install new switch. Test unit and report back.
Mike12656
But should I check the wires going through tube for continuity
Thats I believe where the problem lies not only is switch bad but the wire(s) or ground wire is shorting out
