If you meant engine not turning when you tried to crank it, you need to check battery voltage with the ignition in the run position and the headlights on. Fuel supply would have zero to do with not cranking. However if you meant it would not catch when turned, that could be fuel. Make sure you have good voltage. Some coils and some EFI won't work right with low voltage. If that is Ok then pull the spark plugs, remove the air fan covers and see if you can turn the engine over in both directions by hand. If not pull the valve covers to see which valve is hung open. The valve guide may have shifted or a valve seat dropped. If you can turn it over by hand, and the battery has good voltage then check all the safety switches that prevent the engine from spinning when they are not engaged. Some may only affect the kill wire and not the starter. If that is all good, then I would measure the battery voltage when you turn the starter key to see if the battery is being pulled down, or the starter has a bad connection. My money is a bad valve seat or guide hanging a valve open. I would hesitate on forcing the engine over with the starter until you confirm that a valve is not hitting the piston. If you have a bore scope - and they are inexpensive these days, you can just look into each spark plug hole to see the valve and seat condition. Those are my guesses. Someone else may have an easier path to a solution.
