Hello.
New to Snapper and the forums. I "inherited" an old snapper RER when a tenant skipped out and it appears to be in good shape. I got spark and right away changed the oil. A squirt of carb cleaner at the intake manifold and she fired about six strokes. Well, cool, it has compression and spark and will fire and run!
Knowing the carb would most likely need cleaned, i soaked it in my coffee maker with hot detergent and used carb cleaner and tore it down to clear the jets. I am very impressed with the quality of the carbs on this engine,and yes.they were clogged up. Now the fun part.
The carb linkage is suspect from a previous repair. The fine spring that probably goes from the governor flywheel link to the carb throttle was broken and placed over the outside of a linkage rod. The hand throttle that goes to the nylon pawl gear was binding,and all that stuff that links up there is probably hooked up incorrectly.
I may have to take it to a repair shop unless I can find a really good illustration of how to fix it. i saw a repair manual on here and hope it is for the 3008s. Wish me luck.
