Comparison small zero turn mowers
obielee
what to buy for my first zero turn mower. i was looking at a husqvarna 30 in., 16.5 hp b&s with a manual blade engagement and manual lever for heighth of cut, for 2100. snapper 18.5 hp 33 in. cut with a electric blade engagement and electric height of cut, for 2500. my laen is .88 acres, both mowers have 3 yr warranty. witch company makes the best product and is snapper worth the extra 400 bucks
Well, I have a Toro z4200, and it does well for all I use it for. It has a 42inch deck, with a 19 horsepower kohler courage. You can buy the updated version for about 2500. Not sure about Snapper concerning quality.
I had a snapper yard cruiser with the 13hp briggs and 33 inch deck for 15 years(12 of which before I ever needed to replace a belt.). Mine had the joy stick(instead of much more common lapbars). I recently replaced it with a Country Clipper. Are you sure the deck lift is electric on the snapper? if so that is a new feature vs mine, mine did have an electric pto(blade engagement). I have no idea if their quality is the same but if it were I would not hesitate to recommend it. I bought the Country Clipper off Craigslist for only $2300. It had the one feature I thought I would like, which is an easily maintained deck. The deck slides out from under it for cleaning or maintenance.
