digitalman
We recently had a new house built and want to start maintaining the sodded yard. We have paid a guy to do the law every week, but over the long run is going to cost more then getting a mower and doing it myself.
We don't have a very big yard. It is about 1/3 an acre or slightly larger. It is mostly flat, though near the driveway going into the back yard there is a decent sized slope. It is about 23ft wide and within 17ft stretch drops 4ft. The slide closer to the house is steeper then away from the house.
I have some back issues and think I would rather avoid a push and even self propelled mower. I currently have a toro self-propelled mower that works fin, but just don't enjoy mowing the lawn with it. So a rider would help alleviate some of that frustration
I have spoke to several people and they suggested a single blade rider would be better for my needs. After a lot of searching on the internet, I have realized that more often then not, the single blade riders are the low end models.... which in my opinion are often the ones that have the most problems. Also, I want to park it in my garage so smaller would be better. If I can't get it into the garage, I would have to put it under our deck with a cover over it.... although that is not ideal.
I looked at snapper RER mowers. I have seriously considered getting one, although it seems like a lot compared to a lawn tractor. Plus I am a bit concerned how it will do on the slope. I have read a lot that RER aren't slope friendly. Although one thing I really like about them is it is easier to see directly in front of you to maneuver around things.
When it comes to regular lawn tractors, I want to avoid anything higher then 42in deck.... lower would be better. Though again, it seems like that is hard to find without going low end. I
I have even considered a zero turn, but if i go that way, I would definitely want the smallest one possible.
Ideally, would either come with or have an optional bagger.
I have found several online that look appealing, but it is hard to know if these are smart choices based purely on web info and online reviews. I am very open to suggestions on something else.
Single blade zero turn husqvarna
Single blade tractor husqvarna
Snapper RER (debating which model if I go this route)
snapper single blade zero turn mower
Poulan Pro Single blade zero turn
Dixon Single blade zero turn
Thanks in advance for any help or suggestions you can offer.
