Small unknown part?
Sorry to say, that part is important. You should have two of them. They go over the end of the valve stem and provide a surface for the rocker arm to ride on. When you find the other one fix is not hard. Remove the valve cover, loosen the rocker arms, install these caps and then you must reset your valve clearances.
weedmower77
I discovered where the piece was missing from as I readjusted the valves, thank you for the response.
