skipper
gregjo1948
FH680V right side cylinder skips until it is fully warmed up. Runs on both when started and if throttle is eased open it runs fine. Throttle quickly or engage the blades it drops the right cylinder. New spark plug installed didn't help. Adjusted coil clearance--didn't help. Could it be a weak coil? Thanks, gregjo1948
gregjo1948
Turn out to be a faulty coil. About $66.00 and easy to change and adjust.
