Fred Wells
- Jun 8, 2012
- 1
I have a 2008 61 in Skag Velocity and having electrical problems... blown fuses. One time the mower will start and run with the starter engaged, but as soon as you release the key it shuts off. the next time after checking conectors and having the relay click, mower starts and continues to run when you let go of the key from the start position. While running the engine for a few minutes the fuse holder and wires around it get hot to touch, (I'm gussing around 125 degrees F). The next day the engine starts and runs fine and the fuses are slightly warm. I thought everything was fine untill I engaged the clutch. Then the fuse blew. Im am thinking it might be the relay. How can I trouble shoot the relay? i do have a multi meter. Please Help, Fred
