I have a 2001 Simplicty Stallion 25HP Zero Turn and it will start and run but when it is up on high speed and you engage the pto and then try to go forward up hill it almost dies can mow on flat not to bad but something is going on here. I have replaced the flywheel and installed upper and lower crank seals as they were leaking oil. Not sure if the govenor is bad or what anyone have a idea please let me know.
