Simplicity Courrier/25 HP B&S, ZT-turned mower off and won't start.
4mustangs
  • / Simplicity Courrier/25 HP B&S, ZT-turned mower off and won't start.
I finished mowing Sat and turned my mower off to blow the grass clippings off the deck. When I went to start it, nothing at all. I checked the PTO switch to ensure it was fully depressed, made sure the control bars were in the neutral position, and checked the battery charge, cables, and connections. Nothing. My safety switch is attached to the seat and depresses as it should.
Could it be a bad ignition switch or the seat safety switch?
Go to Simplicitymanufacturing web page & download the parts book and electrical manual
Then you will see that the seat switch is not the root cause of all electical evils in fact they very rarely ever fail .
If there is no power at all then either a battery cable has fallen off or fuse is blown
MParr
Check battery.
Check ground wires and starter connections.
Check seat safety switch.
Check safety switches related to electric parking brake/steering levers.
You’ve already checked that the PTO switch is off.
4mustangs
Thank you, I will do that. I looked through my owner's manual, but no help. Thank you
4mustangs
Check battery.
Thanks for the advice. I will run tests on these things.
4mustangs
If it is a fuse, where would it be located? That was my first thought, but I could not find an inline fuse anywhere, and nothing was mentioned in my owner's manual.
L
Like Toro Simplicity do a wiring diagram book every couple of years with all the models in it .
bkeller500
disconnect and reconnect the cable connections. double check the switch connections. you may have lost a good connection to one of the safety switches. battery post terminal loose?
