Simplicity 23/52 zero turn mower dies under load.
Deano4201
  • / Simplicity 23/52 zero turn mower dies under load.
put in new coils what other things can it be? All help is welcome and thanks you
mechanic mark
See pages 29 & 30 in Troubleshooting Section 2007 Citation.
Please post all numbers from engine: model xxxxxx, type xxxx, trim xx, code xxxxxxx.
Deano4201
386777-0114-E1 07022611
mechanic mark
Read through Operators Manual posted above. Adjust valves with engine cold, specs. are in manual above. Check air filter & pre-cleaner, spark plugs, fuel filter, oil & filter for replacement. I use B&S OEM parts with the exception of oil. I use Valvoline Full Synthetic 5W-30 engine oil 48oz. with filter change.
Run engine at full throttle before engaging PTO clutch & while mowing. I use 93 octane gas with Star Tron Fuel Treatment per instructions on bottle.
