If you are trying to cut more than 1/3 the height of the grass at one time the engines are going to bog down. This is even more true if you are mulching. The bogging down is the result of trying to remove too much too fast.
If you are just mulching, go with the Toro hands down. Huskies are some of the worst mulchers.
What is it that makes the mower a good mulcher? is it the power of the motor? the type of blades? The particular Toro model I mention (20371) has a 6.75/149cc Kohler which apparently is not as powerful as the 7.25/163cc Briggs and Stratton or the Honda GVC160 that is in the two Husqvarnas that I mentioned---would the Toro with the less powerful motor still mulch better than those two Husqvarnas?
Sorry for the double post--I tried to edit a spelling error and somehow screwed it up.
