Sears Yard Vac/Chipper?
elrodp2a
I have a Sears Yard Vac/Chipper and the lasty time I used it doing some vaccuming something broke and it does not suck up clippings any more. There is a spring operated lever/latch that seems to be open or closed and does not help control vaccuming operation?
Any clues to my problem?
Take a look at the blower.. Is something broken or plugging it up? All the sources of intake leaks have to be closed...
Welcome to the forum.. and if you can post a pic of the lever/latch assembly if you can..
:smile:KennyV
Hello, I have moved your post to the Small Engine & Mower Repair Forum. You will have better luck finding assistance there. :wink:
Thanks for joining LawnMowerForum!!!
