Joined the forum to guide me as to how to revive my Sears Craftsman DYT 4000.
It is a small exaggeration to say that this tractor has never... I repeat never worked well for 4 weeks at a time.
It is prone to back firing, not starting, and blowing smoke. The gas line collapsed (some told me that it was the ethanol content of the new gas that kicked the rubber of the hose)... Battery failed, carburetor was replaced (twice)...
So my intention is to get it working again and give it a go.
Let me say that the mower has sat for more than a year without running. The crank case was drained, there is a little bit of gas which I am sure is bad, the spark plug was removed (suggested by a fix it company).
The last money I put into it was a new carburetor. I bought this from Sears, bolted it in place and it did not start, so I lost my heart on this machine and it has sat.
Last Fall I tried to push it out of the way of the snow plow and it wouldn't move... I have been told that the cylinder may be stuck...
That's my tale of woe... Paid a lot of money for this thing with the promise of many years of service... Sears failed me.
So... I am looking for help....
Here is what I am going to do...
1) Air in the tires
2) Oil in the crank case
3) Fresh gas
4) Take the belt off to see if it turns over5
5) Recharge the battery.
6) New spark plug
Question for the group....
1) what to do if the cylinder is stuck....
2) how to get the carburetor to work in sync with the motor
Any thoughts?
1) Air in the tires
3) Fresh gas
6) New spark plug
Any thoughts?
