C chicagorick Forum Newbie May 21, 2012 #3 I tried opening the circuit at the seat as well as jumping the circuit (I believe it needs to be open to run). still cut out whne either brake is release or pto is engaged.
D declid Forum Newbie May 23, 2012 #4 check for broken ground wire, or bad connections, did u test the seat switch with a omh meter to see if its workin,, tom
