five2loves42
- Jul 16, 2014
- 1
- 3
I am having an intermittent starting issue with my stwc61a-27cv ('04 with 362 hours) . It was hard starting and would run the battery down (old battery '04 with only 156/300 cranking amps left when I had it tested), so replaced the battery. This is after checking the fuses and kill switch settings on the drive and mower deck.
It would crank, but not start. Did not smell like it was flooding. In fact seemed like it was not getting fuel or spark. I check and was getting spark. Fuel was coming to the filter out the other side, but did not check further.
Found somewhere online that there was a low oil switch to prevent starting. I had checked the oil and it was between the add and full marks (3/4 of the way to the full mark). I added oil to the full mark and it started fine. Is this a pressure switch or level switch (oil change is coming up so it may have lost viscosity and tripping the no start ?). Also, is there a hydro-oil lockout switch as well? Could this be viscosity on the hydro-oil as well? I have not changed the hydro-oil since I bought this from a friend last year.
Mowed the area around the house (4ac) and shut it down and restarted several times.
I tried to start it and same symptoms as above (grrrr). Check the oil and it was still at the full mark were it was at when I started mowing (really glad there because I was afraid of oil consumption, but that was not the case).
Of course when I went out to check the hours it started on the first crank!!
I am really struggling here. My next step is to check the fuel shutoff solenoid when it fails to start to see if it is getting voltage when I crank, but need someone to help test this.
Any other ideas?
Thanks for your help,
TomV
Any other ideas?
TomV
