cpurvis
While we're spending your money, an option I'd recommend would be the air filter minder system. It's electronic on the Scag. It will pay for itself pretty quickly by preventing you from replacing air filters more often than is necessary. The air filter element on my Kubota is about $30, so I like to get all the good out of them I can. The air filter on a diesel is a critical element and diesels don't tolerate dirty air at all. I had an air filter element failure on a Cat 3406B and the rings were cut out of it in less than 1,000 miles of highway operation. It didn't help that the air filter can was located right behind a front wheel. It was a Donaldson element and to their credit, they paid a pro-rated amount of the cost of the engine overhaul, which amounted to about 1/3rd of the cost.
I've laid out the positive aspects of diesel power. I've owned diesels since 1971 and currently own three; the Kubota, a Dodge Ram and a VW.
Only you can decide if a diesel is right for you and it may not be, depending upon how many hours you'll use it in a year's time. There's an extra cost to buy a diesel and an hourly savings in running it. Divide the extra cost by the hourly savings per year and you'll see how many years it takes to break even.
