Scag tiger cat lever/handle not fully extending
Regalia626
I have a 2015 scag tiger cat 1 with 500 hours. The right drive handle won’t fully extend. I disconnected the rod from the pump and it fully extends so I know it’s not in that linkage. What in the world in the pump is stopping it? Everything sounds fine and operates fine other than losing the speed. The left handle hits the stop, but the right one doesn’t.
Seen those arm control bolts back out and hang on the housing causing your issue that u r having maybe not yours also was this side making any noise at all? Take you a screw driver with some length open up your hydro tank fill cap pull the brass tube out put a magnet on the screw driver and feel around the bottom on the tank try not to get close to the hose fittings because your magnet will stick to them after feeling around in the tank bring magnet up and see if you have any metal on it.
