BrokenTiller
I have a CS30 Ryobi String Trimmer. I don't have specific model/part number for the engine right now, but it is about 9 years old and I am pretty sure the clutch is on its way out if it isn't already totally fried. Last year the shaft snapped and I had to replace it, and when using it this past weekend I noticed that every time I would hold the head on the ground to stop it from spinning the engine dies out as the head slows down. I'm leery of continuing to use it because I don't want to have to put another new shaft on it. Since I've had it apart at least part way before, I know the general procedure, but last year when I tore it down I could not get hte clutch cover off. I know there is a T25 torx screw inside the shaft, but I could not get it off. I 'jammed' the cylinder with a piece of rope, and got the Torx screw inside the shaft to spin a little bit, but it never really 'broke loose' and spun freely. Any suggestions for getting this thing apart?
