hurst1979olds
- Apr 16, 2012
- Threads
- 17
- 79
I have a Ryobi leaf blower. It can be kind of hard to start. You have to gas and pull at the same time. Then once it is running it needs to be left at wide open throttle and 1/2 choke. if you take the choke off, it will die on you. I was going to take the carb apart and clean it. What do you think the base mixture setting for the mixture screw.
