jonnystewart
- Apr 6, 2021
- 1
Hi,
I have a McCulloch partner ride on lawnmower (model no m13592RB)
I was mowing the lawn last week and when the blades are engaged it basically wouldn't cut. (Engine and driving ability wasn't affected)
The belt is fine.. however at the front of the machine where the pulley is, I believe the bearings are gone as per photos. When I manually turn the belt with my hand there is a grinding noise from the pulley area. I think the pulley is fine, but is the bearings in the casing above it. My question is what do you call the part that houses and contains the bearings that I need?
Thanks
Jonny
Thanks
Jonny
