Riddle me this! Any ideas
i have a LA115 jd mower with a single cylinder briggs and strtton , i have a new oem carb, a new oem head , and a new oem coil,
this thing will run for about 8 to 10 minutes and then starts to flood out as if you were pushing the choke on and off with the throttle cable. jusr for a second or two,
any thoughts?
Please post all engine numbers so we have an idea which engine you have. Intek engines used one carb for use with gravity feed systems and another for those equipped with fuel pumps.
Just because that was the only one your JD dealer had available, doesn’t mean it is the correct carb. You have a 16 year old unit and I’m willing to bet they never looked up which engine you have. They changed carbs in 2016. Look on your receipt or call the dealer for the carb number.
