Replacing the drive belt on my John Deere L130 Mower
Guttie72
How complicated is it to replace the drive belt on my John Deere Tractor Model L130?
Take the deck off so you can see what you are doing. The electric clutch should fall off after you remove the center bolt. Hopefully the drive pulley comes off just as easy. Seems like there is a belt guide around the tranny pulley, that isn't hard to get out of the way, but just don't have a lot of room to work to remove. it. the rest of the belt is pretty easy.
