Simple answer, NO. I’ve found that you get what you pay for. I’m not going to recommend any manufacturer as I’ve found you need to rely on your gut. I’ve have always recommended minimum of 375 CCA if you have a single cylinder engine and minimum 425 CCA if you have a twin cylinder engine.
Be mindful of the external size of battery. My former Toro required a shorter battery because it was under the seat, & bouncing could have been an issue..
