Picked up a JD LA165 that my local equipment rental place had taken on trade. I rented it to mow the lawn, ended up liking it, he sold it to me for $250. I was well aware that it was leaking (pouring) oil from the sump gasket. Tore it all down, put in the sump gasket and a crank seal.
I drained the oil prior to the surgery, but as it was sitting upside down, there must have been residual and it was leaking out of intake. When I flipped it over (after gasket install), I let it sit for 24hrs, sprayed some carb cleaner in the spark plug holes and spun the motor over to blow any excess out.
Put in spark plugs. Turn the key with butt in seat and brake engaged, engine just spins forever and never fires. Even tried starter fluid.
Motor: BS 24hp OHV 2cyl 44M777-0128-B1
Here's what I've checked:
Oil level - at spec
Spark plugs - new, not fouled - pulled them like 37 times to confirm, and they are getting spark
Fuel - working/pumping
Carb - taken apart and cleaned (but really it was spotless, not a hint of gunk)
Battery - new
It was a fairly simple procedure, and I don't think there was anything I really could have screwed up when taking the sump cover off. I'm at a loss, it's got fuel, air, and spark. Save me the embarrassment of having to lug this back to the shop I bought it from for service.
EDIT:
And now it gets more weird. I took the valve covers off, removed the plugs, hand spun the motor, I can feel the piston moving, but the valves are just sitting idle.
Video:
Which leads me to believe I must have screwed something up in the sump gasket replacement process. But I don't know what, or how.
thanks
Oil level - at spec
Battery - new
EDIT:
Video:
thanks
