Now winter is coming, I have three tips to keep you and your car safe this winter!
1) Oil - Make sure you have enough oil in the sump, and it is clean. If it is looking a little bit sooty or watery, get it changed, along with the filter, before the snow comes, not after, as when it is extra cold, the engine needs all the lubrication it can get, and worn out oil won't do your engine any favours.
2) Coolant - Make sure your coolant is above the MIN mark, and is clean. If it has been in there for more than three years, I'd recommend you change it with a 50:50 mixture of deionised water and anti-freeze. If it freezes, your block could crack with the expansion, and if you manage to start the engine with frozen coolant, it will overheat.
3) Tyres - Check you have good treads, and the pressure is correct. When it is snowy, your tyres need all the help they can get to grip, so if they are bald and/or under/over inflated, you are risking your car's life, and yours. If you can afford it, I'd recommend you fit winter tyres.
So, follow my wise tips, and you and your car should remain safe this winter.
Ummm.....What's a tyre?
It is a circular object, usually made of rubber that makes cars mobile.Ummm.....What's a tyre?
Thank you for the How To JD! :thumbsup:Good points, all....our vehicles all use the GM Dex-Cool extended life coolant which they say is good for 5 years or 100,000 miles, we do not drive much so I go by the 5 year change interval. Today's shops tend to offer what is called a "coolant replacement" where they hook up your hoses to a gadget that siphons the old coolant out while putting in new. Dumb idea, IMO. That does NOTHING to flush the system out.
Here is how I do it:
Warm engine to operating temp so the thermostat is open, shut off the engine, and CAREFULLY semi-open radiator cap or coolant recovery tank cap. Then CAREFULLY remove lower radiator hose and drain old coolant. Disconnect radiator hoses COMPLETELY when engine is cooler. Then use a shop vacuum with a blower post and the proper attachment (see attachment) :laughing::laughing: to blow out engine block, coolant tank, radiator, etc. You will be amazed at how much coolant may be left in the system. Then, reconnect hoses and fill with water, start engine and let it get fully warm, then drain and blow out the system again, as described. If old cooolant was very dirty, add a commercial flush chemical to the water when you do the filling.
Be sure your car heater is on and set to high when you do both flushings, as there will be coolant inside it. For the REALLY fussy old farts like me, disconnect a hose so you can really drain, flush, and blow out heater core. Reconnect all the hoses and begin refilling your cooling system.
AND BE SURE what coolant you are adding is compatable with the engine and what MAY be left in the cooling system !!! They make coolants today that will mix well with all other types. But check carefully.
When I did the draining and flushing for my GMC last time, despite my care in trying to get all the old coolant and the flushing water out of the system, there were still about a gallon left in the 4 gallon cooling system. Since I was quite sure it was mainly clean water, I carefully added the proper amount of new Dex-Cool and clean water to give me a 65% concentrate of antifreeze. This is the main advantage of doing it my way, you should have a good idea of just how much antifreeze to add. The bad thing is, by doing it my way, you have NO IDEA at all how much you actually drained from your system.....:thumbdown:
The cooling system will take a long time to purge of air after the initial fill so keep checking the level frequently.
Gonna run to the garage and take a pic of the attachment that will be shown in the attachment....:laughing:
Doing the cooling system flush and refill my way is very time consuming and messy but to me it is worth it as I know it was done properly. Simply exchanging old coolant with new is fast and easy but does a very poor job as it mixes them together. :thumbdown:
Yes, that is true if the oil/coolant is clean and new, but if it is a few years old and getting worn, I'm simply stating that it is much better for your car to replace it.My advice,.....fix only what's broke when it breaks.:tongue:
All that, " change this,winterize that" is only to maximize economy for whoever does the advertizing pushing their products.:confused2:
I Do change oil and filters and grease up as recommended though:wink:
A stitch in time saves nine...
Whatever way it is said, it is true...RIGHT...I loved that Fram slogan.....
"You can pay a little more now, or a lot later...."
vehicle maintenance should be a number one concern for all motorist at any time of the year,whether its basic liquid/fluid changes or brakes,tires,exhaust,electrical,chassis components,etc.when a vehicle is on the road and in a non safe condition,it then becomes an accident waiting to happenthis is why i am in favor of FREQUENT oil change intervals.it gives a chance to hopefully spot a potential problem while looking the vehicle over,and yes, trying to find something wrong....hey jd you might want to see if your vehicle has the tiny(2) block drain plugs(not freeze plugs) when changing out your coolant. its probably the lowest point for better drainage. nice to see you are very thorough in your coolant change.
I have several vehicles that I have owned for over 20 years and 2 that is over 25 years old and I have never changed the anti-freeze.
Anti Freeze does not wear out it will protect from freezing forever.
What will happen is the rust protection additives will evaporate and need to be replaced.
I buy a bottle of Prestone coolant system treatment with water pump lube and add a bottle every year.
25 years and the inside of the radiator looks like new.
Jd has spent more time on maintenance in one year than I have in 25. :biggrin:
If you like wasting your time and $$$$$$$$ be my guest but it sure is not necessary.
That is a tire!
For Americans and Canadians it is, for people in the UK it is a tyre.
You're not the only one...I am getting TYRED, oops, TIRED, of all this debate about how the word is spelled.
People from the UK where always a little coockoo :tongue:For Americans and Canadians it is, for people in the UK it is a tyre.
I'd like to say you're wrong... But you're not... :laughing:People from the UK where always a little coockoo :tongue:
Bison said:People from the UK where always a little coockoo :tongue:
Each to his own, there are a lot of people who throw away money on synthetic oils that I consider an obscene, stupid, overpriced waste of dollars, but hey, it's your equipment you treat it as you please. :laughing::laughing:
So, tell us, how many vehicles do you have to care for?
JD you assume that I paid full retail but you know what they say about people that assume you wind up looking like the first three letters in the word ASSume. :laughing:
I have a large oil stash I buy it when the price is right not wait till I need it.
What is in my car now I got a $15.00 per 5 quart rebate on but advance auto had a $10.00 instant rebate on any purchase over $20.00 so i printed several coupons and went to AA and bought a 5 quart jug gave them my 10 dollar instant rebate and got the oil for $11.00.
I sent my wife in to buy one also.
Then on the way to the Meijers store I stopped at the south side AA and bought 2 more jugs.
I sent in the rebates under my name and my wife/daughter and a friend so I got 40 bucks instant rebate at AA and got 60 bucks back from SOPUS so they paid me 16 dollars to use there oil.
Still sound stupid and overpriced
Maybe you are the one paying too much for your oil. :biggrin:
Hmmmmmmmm?
Hmmmmmmmm?
I'm paying $33 per 4.5 liters on sale here in Canada for Castrol Syntec.
Mobil 1 here at AA is $30 per 5 quarts, it has been a LONG TIME since it was sold for $21 for 5 quarts.
And you are 100% right :thumbsup:IMO synthetic is WAY, WAY overpriced compared to conventional oils. WAY OVERPRICED. And except in very extreme operating conditions it provides no better engine protection. Nowhere enough to justify paying 2X-3X the price of conventional oil.
The only reason i would use synthetic is in a diesel that has to sleep outside in the winter cause it'll start easier
At the motor parts store I buy my oil from, there is only a price difference of about 」5/$8 between Mineral oil and Synthetic.
Personally, I use Synthetic, as it doesn't cost that much more, and in the long run, it will help my engine last longer, and also quietens the lifters a lot. With Mineral oil they really knock.
WRONGMINERAL OIL???? :confused2::confused2: Do you know what MINERAL OIL is here in the USA? No wonder your engine knocks if that is what you use.
What are you using synthetic oil in?
Here, mineral oil is mainly used to remove ladies's makeup, and season wood cutting boards, utensils, bowls, etc. The only mechanical application it has...hydraulic fluid, cutting oil, and lubricant...BUT NOT FOR ENGINES !!!!!
WRONG
What most refer to as conventional oil has a mineral oil base.
Group I Group II and Group III all use a mineral oil base.
OK, go to this link - Carlube 15W40 Mineral Engine Oil (1 Litre)I have NEVER, repeat NEVER, known ANYONE to refer to conventional motor oil as "mineral oil" EVER !!!!
EXCEPT for JMurray01. Next time I go to Advance Auto I will be sure to ask for "mineral oil" and get their reaction...:laughing:
Hey JM, next time you go to a drugstore find out what mineral oil is labeled as....:laughing:
I'm not starting a fight with you JD, I'm just saying that I'm right :thumbsup:
The guy at Advance Auto will know what it is.
Anyone who know anything about motor oil knows is has a mineral oil base unless you are talking about a GRP IV or GRP V GRP IV is a PAO base and GRP V is a Ester base all others are mineral base always has been.
Let me ask you this what did you think conventional oil was made of.
Evan a blind squirell will find the nut eventually. :laughing::laughing::laughing:
Even a blind, deaf, pawless, toothless, olfactory deprived SQUIRELL (sic) will find the nut eventually, especially in my front yard right now.
I'll bet you have some fat ones, real tree shakers.
