jmurray01
, , 1,000 Post Club
- Apr 7, 2011
- Threads
- 129
- 1,490
Now winter is coming, I have three tips to keep you and your car safe this winter!
1) Oil - Make sure you have enough oil in the sump, and it is clean. If it is looking a little bit sooty or watery, get it changed, along with the filter, before the snow comes, not after, as when it is extra cold, the engine needs all the lubrication it can get, and worn out oil won't do your engine any favours.
2) Coolant - Make sure your coolant is above the MIN mark, and is clean. If it has been in there for more than three years, I'd recommend you change it with a 50:50 mixture of deionised water and anti-freeze. If it freezes, your block could crack with the expansion, and if you manage to start the engine with frozen coolant, it will overheat.
3) Tyres - Check you have good treads, and the pressure is correct. When it is snowy, your tyres need all the help they can get to grip, so if they are bald and/or under/over inflated, you are risking your car's life, and yours. If you can afford it, I'd recommend you fit winter tyres.
So, follow my wise tips, and you and your car should remain safe this winter.
