Here is the deal: 3-4 years ago, it started not to crank unless you gave the rotor an extra hand.  Sat for 1 year unused.  Bought a solenoid, and replaced starter spring and plastic parts and seemed to work fine for a while.  Started having same problem this year after a few cuts.  Once you turned ignition key the starter would engage but stop.  Adjusted carburetor, adjusted valves, replaced starter, checked battery, replaced spark plug, disengaged the seat switch and clutch switch has continuity. Ignition switch checked and has continuity. Even bought a 2nd solenoid and installed this today. When you turn starter switch, it just clicks.  Traced ground wire and all appears to be in order and the wires to starter appear good.  Tested from magneto to spark plug but no fire.  WHAT IS WRONG WITH IS MACHINE!
I am counting on someone to provide me the magic bullet.
