kwhites634
Problem started a couple days ago on my 15 yr old Dixie XW2002, with the 20hp Kohler engine. Had been started an hour earlier with no problem, but after loading the cart I was pulling, all I got was a 'click' when I hit the switch. Not a chattering as I'd expect with a low battery or dirty terminals, but just a single click. Subsequent attempts didn't yield any sound at all. Had the battery checked; it's o.k. Next suspect was the starter, which I removed and had tested; the Bendix spun just fine when hooked to a test battery,but failed to operate when wired back up (w/o remounting on engine) to my machine, with the key on. I'm not anything close to being a competent mechanic, but my next inclination is to replace the switch and wiring harness from the switch to the starter. I've already removed the switch and cleaned the terminals with no postive results. Even then I'll still have the starter to re-install. Since it was bench tested, the bendix teeth aren't lined up with the teeth on the flywheel, so I'm assuming I have to remove the top cover of the engine, which I've never attempted, so I can see what's going on.
Does all the above sound like I'm headed down the right road? I just dropped $2400 in repairs on this machine late last season at the local Dixie dealer (after they'd told me the bill would be about $1600), so I'm disinclined to put the old girl in the shop again if I can avoid it, especially this time of year. Any input or suggestions would be greatly appreciated.
