N nicholshornlake Member Jun 25, 2013 #1 Would narrowing the stops on the steering underside let it turn shorter?
Carscw Lawn Pro Jun 25, 2013 #2 nicholshornlake said: Would narrowing the stops on the steering underside let it turn shorter? Click to expand... Do you want to turn sharper or not turn as much? (( racing is the only sport that you need two balls ))
N nicholshornlake Member Jun 25, 2013 #3 Carscw said: Do you want to turn sharper or not turn as much? (( racing is the only sport that you need two balls )) Click to expand... Turn sharper
