Rated Output Question
bartles
I have a B&S model 125K02-0477-E1, s/n 04122858. I thinking about replacing it with a Honda engine from a power washer.
What is the rated RPM of the B&S engine? I can locate that data within the B&S website.
Usually 3600 RPM is considered the normal max RPM. But you must consider the max rated rpm of the pump being driven.
Crankshaft Specifications​
Service Part Number797017
PTO TypeStraight
PTO Woodruff Key2x #605
PTO Keyway #1 (in)0.25 x 1.520 x 0.146
PTO Keyway #1 (mm)6.35 x 38.608 x 3.708
PTO Keyway #2 (in)-
PTO Keyway #2 (mm)-
PTO Thread Size0.375-24 UNF
PTO Diameter (in)0.984
PTO Diameter (mm)25
PTO Length (in)3.156
PTO Length (mm)80.162
bartles
Gee, thanks for the crank info! The Honda pressure pump engine is rated at 3400 RPM...should be a good match for power.
sgkent
he gave you the crank specs because the replacement engine must fit the pressure washer pump. They are not all the same.
bartles
Right, I got that....saves me measuring time.
