Anyone else thinks that grass looks pretty damn good?!?!?Nice yard.
That's some thick looking grass. The RSD deck is shallower and will have some issues with real heavy material volumes as such. A rule of thumb for grass health and cut quality is at most remove 1/3 of grass length, perhaps cut it a touch more often?
Two elements determine the discharge and even dispersing of clippings for a clean cut but only one is thought to be the problem by owners of mowers and that one element is the blades. Change to this blade or that blade is usually the suggestion with disappointing results.
The second element is deck design and the engineering relationship of the blade to the deck. There are just some mowers that will never do the job you want to see no matter what blade is installed.
I'm sure this isn't what anyone that spends thousands for their pretty mower wants to read or hear but it is fact.
I'm bought in with this idea, but what no one ever talks about is what attributes of either the blades or deck actually have an impact on cut quality. As an engineer, I'd love for someone to be able to point to something specific on the deck of my mower that is causing the issues I see.
I had a similar question about blade design that I posted on this forum or another some time back. I see so many posts where people suggest, "try high lift blades", or "try gator blades", but so little discussion of the science behind why one blade might be better than another for its intended purpose.
Not arguing with your point at all, just wishing we as an internet community could get more science behind the discussion to help understand the issues we're seeing, or at least help others make good choices.
I think if you were to use a set of high lift blades it would give you a better cut. It should give you better lift and discharge.
So where does front to back deck level adjustment come into play when using Gator Blades? I can't say what the OP's deck adj. spec is but on my Xone it's 1/4" lower in front than back. This goes against everything I've used when adjusting the deck on a garden tractor....which is 1/4 HIGHER in front.
I'm wondering if all the posts about wanting a better quality of cut...if the OPs' would adjust the decks to run 1/4" high in front. I've now got my XOne running 1/4" high in front with Gator blades. Just need the grass to grow to see if the QOC is better and leaving behind smaller clippings.
