Raised CMM1200 by cutting height adjustment plate end projection even with teeth.
Robert Gift
  • / Raised CMM1200 by cutting height adjustment plate end projection even with teeth.
Now the mower goes one tooth-increment higher - whatever that is.
Can I make it go even higher for our backyard grass?
We need to conserve water. Does higher grass retain more water and grow less?
(Sheeler, our used poodle from the animal rescue, loves to bound through the tall grass.)
Thank you.
Robert
SeniorCitizen
In general, a leaf with a bigger surface area will transpire faster than a leaf with a smaller surface area.
But for a full understanding of transpiration try reading this.
https://en.wikipedia.org/wiki/Transpiration
