And sometime it even takes a 5/16 reamer. It is basically the same setup as the Peerless and Splicer mower transaxles. Now the Peerless and Splicer manual multi speed transaxles are truly multi speed units.
And as for the transaxle it is a single speed transaxle with a CVT pulley system. MTD has two flavors of the system. One that use a stepped tension system like the one you have and the Auto Drive version that variable tension.
I have customers that want to argue with me that they have an automatic transmission especially when I change the two drive belts on the MTDs
