Those that like spending money on repairs.You KNOW who mows over sticks and even stumps and bricks/rocks, don't you!
The only thing I'm going to address is you need to bring it to the man you see the man knows more than you oh wait a minute you brought it to the man there's some clown on here who will trash you if you don't bring it to the man so wherever you can get help to fix your problem that's where you want to go.Hi, I have quick change oil valve on my Troy bilt Pony 2020.
I changed the oil yesterday. I drained it after mowing on a hot mower. the lawnmower shop owner had given me the wrong filter. It spun on but was slightly larger for a Kawasaki. I didn't realize until it was all apart.
Anyway, he had to order the right one. I re-changed the oil last night. First off, I had trouble pulling that yellow plastic valve out the second time around after turning it and getting it out of the detente. It seemed really tight to pull out. I pulled harder and it pulled out too far, making a nice mess. The little nipple on the metal part that guides through the plastic to lock it came through the factory slit. (The Part closest to the motor.
I pushed it back on and cleaned up changes the oil etc.
my question is how can I make that plastic part a little easier to pull. I cleaned it up with a toothbrush. Is the plastic part replaceable on its own? I read a Thread on here that a Said you can remove that plastic piece to tighten the actual metal valve down.
Does anyone have one of these things disassembled . I am trying to picture how this functions internally.
Does Famuto make drain valves for lawnmowers? I have one on all my vehiclesHi, I have quick change oil valve on my Troy bilt Pony 2020.
Something like this.Hi, I have quick change oil valve on my Troy bilt Pony 2020.
You can actually eliminate that by replacing it with a piece of galvanized pipe cut slightly longer for easy access. Match the threads and on other end put a screw on cap to prevent leaking.Hi, I have quick change oil valve on my Troy bilt Pony 2020.
