Question about those devices that eliminate points on older mowers such as "D" series
Older Lawnboy mowers with "C" and "D" series engines often have points unless very late model D-600 engines. Those engines that have points have a mechanical centrifugal advance that allows easy starting with the timing retarded, then as the engine speeds up advances the timing for efficiency and power. I found an old D-400 series mower I am restoring that has had one of these devices added, and the points and condensor removed from the circuit. It gives a good spark with the original coil, but I wonder if the retard-advance feature on these Lawnboys is not present in the solid-state replacement for the points. Its a very tiny little thing. I am probably going to put it back to points and condensor, as I like things original. Any observations on these devices?
