putting carb back together.. which way does spring go?
troybilt pony
  • / putting carb back together.. which way does spring go?
was taking apart the carb and this spring fell loose. didn't get a look at it before it happened. does anybody know which way it goes?IMG_3526.jpgIMG_3527.jpg
Put the spring in the big hole in your second picture, with the cap facing you. Install the diaphragm on top of that and then install the cover.
