Yes thank you Boo the 1st picture and second picture is perfect for Wolf to see how his is supposed to be.....
Wolf are you still with us Mon Ami ???
Il Engine how do you think that bracket got bent like that ??? For sure it wasn't a branch that hung up on it.... Maybe a corner of something hard that he went under or somebody did that to make the engine run a lil faster OUCH ........
Thanks for the images you guys. That helps a bunch and I see what you're referring to now about the part that's bent. I have no clue how I did that but I think you're on to something with that...
I'll try to bend it back and see what comes of it. I'll update this thread with what comes of it. Hopefully the thing will be normal after this because I sure don't want to buy a new mower right now.
Hey guys--I meant to update this yesterday but I've been dealing with all sorts of things on my end (i.e. - contractor stuff, bad internet at home, tons of work going on, etc.)--but what I was going to say is that it was definitely the bend with that metal frame / support that caused the governor / speed issue (I mowed the yard this weekend and while I had to fiddle with missing bolts, etc. I was at least able to finally get the yard mowed after reinserting bolts where they were needed).
Thanks for the help with all this. You've saved me some money.![]()
