Walk behind Purchased Two Back Wheel Adjusters With The New Bushings
Roymg
  • / Purchased Two Back Wheel Adjusters With The New Bushings
Hi,
Both of these assemblies are marked for Left and Right sides but they both appear to be made the same. I don't see any difference so does it really matter what's left or right?
Another stupid question is from what end of this mower do you look at to determine left or right side? Front or back?:smile:
Yeah, I bought one that wont roll backwards when hot. HRR216K9VKAA. I know there is warrantee work from Honda for this problem but decided to handle it myself. Parts are not that expensive and I will dissemble and rub down the axle a bit. The newer parts are suppose to be redesigned but who knows what you will get off a shelf from a parts store.
Got mine from PartsTree.
Got answer on Left And Right its looking from the back and the old adjusters are also marked with L and R. Any diff in the two, not sure.
mechanic mark
good deal, keep water hose away from mower.
