ancient11
- Apr 1, 2012
- 3
- 13
Since this mower was new, every time you try to engage the blade it dies unless you are real fast engaging, disengaging, engaging, disengaging, engaging again.
I have taken the belt off the clutch and turned it by hand to see if it turns freely and it does, so the deck and belt system is not the problem. i have put a meter on the clutch to check the amount of draw and it does not seem to be excessive.
I have had a lot of problems with the seat switch causing me untold misery. First the engine would not start and I finally traced it back to that unethical idiot switch they call a seat switch. Then shutting down for no reason and engine skipping all because of the idiot switch. i want to blame this on that plague but i can't see how the seat switch would cause the engine to die when engaging the blade. AlthougH I must admit I am ready to bypass the seat switch. I have put three new seats switch's in.
Any thoughts or help on this would be greatly appreciated.
